1 - 20 of 29 Posts
Here is a data compilation from various sources (links at the end of post) feel free to suggest any adds or corrections!
Wheel Tire Vehicle Car Automotive parking light
I4 eDrive40
Vehicle Car Wheel Tire Automotive lighting
I4 M50
Base price in EU
58 300€​
69 900€​
🚗 BODY
No. of doors / seats
5 / 5​
Length/width/height
4783 / 1852 / 1448mm​
Wheelbase
2856mm​
Track, front/rear
1601 / 1630mm​
1589 / 1606mm​
Ground clearance (unladen)
125mm​
Turning circle
12.5m​
Weight, unladen (DIN/EU)
2050 / 2125kg​
2215 / 2290kg​
Weight distribution (unladen), front/rear
45.1 / 54.9%​
48.1 / 51.9%​
Max. load to DIN
555kg​
520kg​
Max. permissible weight
2605kg​
2735kg​
Max. axle load, front/rear
1140 / 1550kg​
1270 / 1550kg​
Max. trailer load, braked 12%/unbraked
1600 / 750kg​
Max. roofload/towbar download
75 / 75kg​
Luggage comp. capacity
470 – 1290L​
Air resistance (Cxm²)
0.24 x 2.31 = 0.55​
0.25 x 2.33 = 0.58​
POWER UNIT
Drive concept
transmission of the electric motor’s drive torque to the rear wheels
coordinated on-demand transmission of the drive torque from two motors to front and rear wheels respectively
Driving Modes
EcoPro, Comfort, Sport​
EcoPro, Comfort, Sport, Sport Boost​
Max. System Power
250kW / 335hp​
350kW / 476hp
400kW / 544hp (Boost)​
Max. System Torque
430Nm​
730Nm
795Nm (Boost)​
Power-to-weight ratio
0.12 kW/kg​
0.15 kW/kg
0.17 kW/kg (Boost)​
Max. Recuperation
116kW​
195kW​
Recuperation modes
Low, Average, High, Adaptive. D, B​
Type of transmission
Automatic transmission, single speed with fixed ratio​
Rear motor
Peak output to ECE R 85
250kW / 340hp​
230kW / 313hp​
Max. Torque
430Nm​
395Nm
430Nm (Boost)​
Gear ratio
8.774:1​
8.774:1​
Front motor
190kW / 258hp​
Max. Torque
335Nm
365Nm (Boost)​
Gear ratios
8.774:1​
🔋 BATTERY
Storage technology
Lithium-ion​
Installation
Underfloor​
Voltage
398.5V​
Battery capacity
210.6Ah​
Energy capacity, gross
83.9kWh​
Energy capacity, net
80.7kWh​
Recommended use range
10–80 %​
🔌 CHARGING
Type
Combined Charging Unit (CCU) with built-in 4 kW voltage transformer for supplying 12V
Max. charging rate AC, single-phase
7.4kW​
Max. charging rate AC, three-phase
11kW​
Max. charging rate DC
210kW​
Charging, 10-80% / 0-100%
27h04 / 51h13 (1.8kW)
24h44 / 40h05 (2.3kW)
7h41 /12h28 (7.4kW)
5h10 / 8h23 (11kW)
2h49 / 4h10 (20kW)
1h08 / 1h46 (50kW)
25min / 51min (200kW)
🦘 DRIVING DYNAMICS
Suspension, front
Double-joint spring strut axle in lightweight aluminum-steel construction, hydraulically damped torque strut bearing
Suspension, rear
Five-link axle in lightweight aluminum-steel construction;
Suspension, rear
(opt) air suspension with automatic self-levelling
Suspension mode
optional : Comfort, Sport, adaptive​
🗺 KM RANGE
(WLTP, EcoPro)
Impact of T°C, overland/highway
455 / 325km (-10°C)
580 /375km (+10°C)
520 / 365km (+30°C)​
415 / 300km (-10°C)
520 /340km (+10°C)
470 / 335km (+30°C)​
Impact of Speed, @14°C (avrg. speed without stops/max speed)
640km (25 / 56km/h)
590km (42 / 75km/h)
545km (60 / 94km/h)
460km (77 / 113km/h)
395km (94 / 131km/h)
565km (25 / 56km/h)
525km (42 / 75km/h)
490km (60 / 94km/h)
415km (77 / 113km/h)
355km (94 / 131km/h)
Impact of Driving Mode
0%(EcoPro)
-13%(Comfort)
-37%(Sport)​
Impact of Wheels
-1% (17' style 851)
0% (17' aero style 852)
-2% (18' style 853)
-2% (18' aero style 854)
-2%(19' aero style 855)
-8% (20' style 862)
0% (18' style 858)
0% (19' style 859)
0% (19' style 860)
-1% (19' style 861)
-8% (19' style 861 M)
-8% (19' style 859 M)
-5% (20' style 862 l)
-16% (20' style 868 M)
Impact of Options
-10% (active suspensions)
-2% (aero kit)
-2% (spoiler)
-1% (M breaks)
-1% (sun roof)
-1% (sun roof)
-1% (spoiler)
🚀 PERF.
Max speed
190km/h​
225km/h​
0-100km/h
5.7sec (Sport)​
3.9 sec (Sport)
3.7sec (Boost)​
¼ mile
13.7sec (Sport)​
11.7sec (Sport)​
10sec race
231m (Sport)​
305m (Sport)
314m (Boost)​
max acceleration
0.5G​
0.76G (Sport)
0.8G (Boost)​
🕹 ELECTRONIC
OS
iDrive 8, included Personal Assistant​
OS compatibility
Apple carPlay, Android Auto​
Sound
200W, 10 speakers, 7 channels, (mini)subwoofer in the doors, center speaker
Harman Kardon (opt) : 535W, 17 high-end speakers, 9 channels, subwoofer in the boot, 2 tweeters integrated into the front doors
Sensors
Front camera. (opt), Camera behind the windshield. (opt), Top view cameras, Rearview camera, Front radar sensor, Radar sensors side front rear, Ultrasound sensors in the front/rear bumpers, Ultrasonic sensors side
Connectivity
Bluetooth, Wifi, eSim, USB​
Security
Collision warning systems (opt) , Forward Collision Mitigation, Approach control warning with light braking function, Daytime Pedestrian Collision Mitigation, Intersection warning with City light braking function, Evasion Assistant, Lane Departure Warning, Active Blind Spot Detection, Side collision mitigation, Rear-end collision preparation (opt), Emergency Stop Assistant, Cross traffic warning, Drive Recorder, Active Protection (opt), PostCrash iBrake, Fatigue alert, Driver Attention Camera (opt)
Assistance
Speed warning, Manual Speed Limiter, Cruise Control without or without distance control, Speed Limit Assistant, Steering Assistant, Assisted Driving Plus, Automatic Lane Change Assistant, Lane change with active, guidance, Parking Assistant, Automatic Parking Assistant, Back-up assistant
Drive assist
Antilock Braking System ABS, Brake assistant, Adaptive brake assistant, Dynamic Stability Control, Dynamic Traction Control, xDrive, Servotronic, Variable sport steering
💸 OPTIONS
✔ : included, Opt: option, ❌ : not available
Active suspension
Opt.​
Alarm system
Opt.​
Ambient light
Opt.​
Drive Recorder
Opt.​
Iconic Sounds
Opt.​
Laser light
Opt.​
Colors
Schwarz Black
Alpine White
Saphirschwarz
Mineral White
Sunset Orange
Skyscraper Grau
Dravitgrau
Tansanitblau
Aventurinrot
Alpinweiss
Saphirschwarz
Mineralweiss
Sunset Orange
M Portimao Blau
M Brooklyn Grau
Sanremo Green
Dravitgrau
Tansanitblau
Aventurinrot
Frozen Portimao Blau
Comfort access
Opt.​
Drive assist pro
Opt.​
Drive recorder
Opt.​
Glass roof, electrical
Opt.​
HUD
Opt.​
Wireless phone charge
Opt.​
M Carbon exterior package
Opt.​
M high-gloss Shadowline
Opt.​
M high-gloss Shadowline with extended contents
Opt.​
M Lights Shadowline
Opt.​
M rear spoiler
Opt.​
M Sport brake, red high-gloss
Opt.​
M Sport brake
Opt.​
M Sport seats for driver and front passenger
Opt.​
Park assist plus
Opt.​
Seat heating for driver and front passenger
Opt.​
Seat heating front and rear
Opt.​
Seat with active seat ventilation
TBD​
TBD​
Sellerie
Sensatec Schwarz
Vernasca Tacorarot
Vernasca Schwarz
Vernasca Mocca
Vernasca Oyster
Sensatec perfore Schwarz
Sensatec Schwarz
Vernasca Tacorarot
Vernasca Schwarz
Vernasca Schwarz M
Vernasca Oyster
Vernasca Cognac
Steering wheel heating
Opt.​
Sun protection glazing
Opt.​
Dimensions
Automotive parking light Tire Car White Vehicle
Flexible Fast Charger (Mode 2)
Rectangle Font Material property Parallel Circle
Graphics
Azure Slope Rectangle Font Parallel
Power / Torque (RPM)
eDrive40
M50
Rectangle Plot Slope Font Parallel
Rectangle Slope Plot Font Parallel
WLTP Range (EcoPro, High recuperation)
eDrive40
M50
Slope Rectangle Plot Line Parallel
Slope Rectangle Line Plot Parallel
eDrive8 MENU
Code:
All apps >Assistance
All apps >Automate habits
All apps >Device manager >Connect new device >Use Android Auto
All apps >Device manager >PERSONAL eSIM >Settings
All apps >Device manager >Personal eSIM >Telephone functions via eSIM >Link telephone
All apps >Device manager >Settings >Telephone priorities
All apps >Device manager >Settings >Vehicle ID (VIN
All apps >Drive Recorder >Recording >Start recording
All apps >Drive Recorder >Recordings
All apps >Drive Recorder >Settings >Allow recording*
All apps >Drive Recorder >Settings >Camera selection
All apps >Owner's Manual
All apps >Personal Hotspot >Connect new device >Activate internet access
All apps >Personal Hotspot >Settings >Internet access for mobile devices
All apps >System settings >Remote Software Upgrade >Search for upgrades
All apps >Wi-Fi connections >Connect new device
All apps >Wi-Fi connections >Settings
Vehicle apps >Charging >Charging mode >Charge immediately / Charging in time slot
Vehicle apps >Charging >Charging mode >Charging in time slot
Vehicle apps >Charging >Charging target
Vehicle apps >Charging >Current limit >Current limit
Vehicle apps >Charging >Departure plan >Pre-conditioning for departure
Vehicle apps >Charging >Fan loudness
Vehicle apps >Charging >Unlock charging cable / Unlock charging cable now / Stop and unlock charging cable
Vehicle apps >Charging >Unlock charging cable >Unlock charging cable when charging finishes / Unlock charging socket cover permanently
Vehicle apps >Climate control
Vehicle apps >Displays >Control display >Brightness at night
Vehicle apps >Displays >Head-up display
Vehicle apps >Displays >Instrument cluster >Display Assisted View when Driver Assistance is active*
Vehicle apps >Doors and windows >Comfort access >Unlock when approaching >Lock when walking away*
Vehicle apps >Doors and windows >Digital Key >Reset function
Vehicle apps >Doors and windows >Key Card >Deactivate Key Card
Vehicle apps >Doors and windows >Lock/unlock >Flash on lock/unlock >Sound on lock/unlock
Vehicle apps >Doors and windows >Lock/unlock >Fold mirrors on lock/unlock
Vehicle apps >Doors and windows >Lock/unlock >Lock after a short time*
Vehicle apps >Doors and windows >Lock/unlock >Standby mode when doors opened*
Vehicle apps >Doors and windows >Lock/unlock >Unlock >Driver's door only / All doors*
Vehicle apps >Doors and windows >Lock/unlock >Unlock doors at end of trip >Unlock doors when in Park*
Vehicle apps >Doors and windows >Tailgate >Open with foot movement >Close with foot movement*
Vehicle apps >Doors and windows >Tailgate >Opening height
Vehicle apps >Doors and windows >Tailgate >Tailgate >Tailgate and door(s >Tailgate will only open if vehicle is already unlocked
Vehicle apps >Driving settings >Driver Assistance >Driving >Assisted Driving >Automatic Lane Change*
Vehicle apps >Driving settings >Driver Assistance >Driving >Speed Limit Assistance >Adjust distance based on conditions
Vehicle apps >Driving settings >Driver Assistance >Driving >Speed Limit Assistance >Adjust to route >Automatically adjust speed to route
Vehicle apps >Driving settings >Driver Assistance >Driving >Speed Limit Assistance >Adjust to route / Automatically adjust speed to route
Vehicle apps >Driving settings >Driver Assistance >Driving >Speed Limit Assistance >Speed limits >Adjust manually / Show anticipation / off*
Vehicle apps >Driving settings >Driver Assistance >Driving >Speed Limit Assistance >Speed limits >Show current limit
Vehicle apps >Driving settings >Driver Assistance >Driving >Speed Limit Assistance >Warning when speeding >Show excess speed
Vehicle apps >Driving settings >Driver Assistance >Feedback via steering wheel >Light elements
Vehicle apps >Driving settings >Driver Assistance >Feedback via steering wheel >Vibration intensity
Vehicle apps >Driving settings >Driver Assistance >Parking and maneuvering >Active PDC emergency braking
Vehicle apps >Driving settings >Driver Assistance >Parking and maneuvering >Automatic PDC activation
Vehicle apps >Driving settings >Driver Assistance >Parking and maneuvering >CROSS TRAFFIC WARNING
Vehicle apps >Driving settings >Driver Assistance >Parking and maneuvering >PDC signal volume
Vehicle apps >Driving settings >Driver Assistance >Parking and maneuvering >Sound when available*
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Active Blind Spot Detection >Steering intervention
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Active Blind Spot Detection*
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Forward Collision Mitigation >Early / Medium / Late
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Forward Collision Mitigation >Off*
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Lane Departure Warning >Early / Medium / Reduced
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Lane Departure Warning >Off*
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Lane Departure Warning >Steering intervention*
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Reset to recommended settings
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Side collision warning*
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Speed warning >Adopt current speed
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Speed warning >Warning at:
Vehicle apps >Driving settings >Driver Assistance >Safety and warnings >Drowsiness detection assistant*
Vehicle apps >Driving settings >Drivetrain and chassis >[DRIVE MODE] INDIVIDUAL
Vehicle apps >Driving settings >Drivetrain and chassis >Energy recovery in D
Vehicle apps >Driving settings >Drivetrain and chassis >IconicSounds*
Vehicle apps >Exterior lighting >Additional settings >Daytime driving
Vehicle apps >Exterior lighting >Additional settings >One-touch turn signal
Vehicle apps >Exterior lighting >Additional settings >Pathway lighting
Vehicle apps >Exterior lighting >Additional settings >Welcome and goodbye*
Vehicle apps >Interior lighting >Ambience >Ambient lighting*
Vehicle apps >Interior lighting >Ambience >Brightness
Vehicle apps >Interior lighting >Ambience >Color
Vehicle apps >Interior lighting >Ambience >Dynamic light*
Vehicle apps >Interior lighting >Ambience >Reduced for night driving
Vehicle apps >Live Vehicle >Content >Trip data
Vehicle apps >Live Vehicle >Content >Vehicle status >Check Control
Vehicle apps >Live Vehicle >Content >Vehicle status >Flat Tire Monitor
Vehicle apps >Live Vehicle >Content >Vehicle status >Required services >Vehicle inspection >Date:
Vehicle apps >Live Vehicle >Content >Vehicle status >Tire Pressure Monitor >Perform reset
Vehicle apps >Live Vehicle >Content >Vehicle status >Tire Pressure Monitor >Tire settings >Tire selection >Manual >Tire type >Other tires >Save tire settings
Vehicle apps >Live Vehicle >Content >Vehicle status / Vehicle status / Adaptive content
Vehicle apps >System settings >Data privacy*
Vehicle apps >System settings >Date and time
Vehicle apps >System settings >Language
Vehicle apps >System settings >Personal Assistant >Online speech processing
Vehicle apps >System settings >Personal Assistant >Response length
Vehicle apps >System settings >Personal Assistant >Speaking during voice output
Vehicle apps >System settings >Personal Assistant >Wake word >Hello BMW*
Vehicle apps >System settings >Personal wake word >Set >Start recording
Vehicle apps >System settings >Pop-ups
Vehicle apps >System settings >Reset vehicle data >Reset vehicle data
Vehicle apps >System settings >Third-party providers
Vehicle apps >System settings >Time period for trip data >Reset Individual
Vehicle apps >System settings >Time period for trip data >Values >Since start of trip / last charge / factory / individual
Vehicle apps >System settings >Touchpad
Vehicle apps >System settings >Units
Vehicle apps >System settings >Valet parking mode >PIN
Vehicle apps >System settings >Wireless charging tray >Mobile phone reminder
Sources
  1. BMW:
    1. i4 Online tools
    2. i4 Owner’s manual
    3. i Navigation / Entertainment / Communication Guide
    4. Flexible Fast Charger (Mode 2) Manual
    5. i4 Technical spec
    6. i4 iX Media launch
    7. i4 Specification guide
    8. Videos
  2. Others:
    1. Technical spec #2
    2. Battery Charge
    3. WLTP driving cycles
Re: WLTP
Sorry I dont get this!
City Highway
415km / 300km (-10°C)
520km /340km (+10°C)
470km / 335km (+30°C)
That means abouve 10°C the M50 only drives 340km from 100% to 0% at which speed (100km/h?). So since you probbaly never drive down the battery less then 15% it would make only about 300km?
Then you actually never charge 100% because the last 20% take much longer? Which means next distance untill charging is only about 70% of capacity which equals about 240km ?
My next concern is that in Germany you actually drive at 160 - 170 km/h at least on some roads, even in France or Italy I tend to drive close to 150.
So thats another -20 till -30% ?
So after that calculation that means not that much more then 200km distance at arround 160km/h on a highway?
Which means about 4 x 35 minute stops, if you are lucky and get a fast charging station if you want to drive 1000km ?
So thats 2h idealy.
If you are not lucky? What does that mean 3-4h ?
This seams not that practically to me.
Of cause with a combustion car I stop about 4 Times too, but then I jog arround the Gas Sation 5 Minutes and eat and drink and get patrol once, that not that much abouve 1h.
iX3
Re: WLTP
City Highway
So thats 2h idealy.
Well, that's part of driving an EV.
To get a better range, you need to apply an other driving style compared to driving and ICE.
@WLTP, highway = 131 km/h max
It also depends on drive mode :
165km/h ~ [email protected] / [email protected]
150km/h ~ [email protected] / [email protected]
If you are lucky and get a fast charging station if you want to drive 1000km ?
Be aware that in France, you will not be lucky
It's EV-way of life
travel with 3 persons plus baggage, so thats another factor of how many minus %? 10?
yes : let's say 3x75kg + 50kg = 275kg
Car weight + passenger ~ 2365kg
=> +11% weight => -11% range (if ratio is linear)
i dont see an issue with discharging to 5% - it is not an ICE where you start looking for gas station when you hit 100km mark - here it is much more accurate and gives you battery status like your phoe up to 1% not 1/4 of a gas tank
as for any question of simulation - use ABRP (abetterrouteplaner) website to do the simuylations - you can set additional weight there, temperature, max speed, even rain or snow and see how often and how long you should be charging
Reactions: M.Juul
I think stacking everything on top of each other isn't realistic or fair. If you know you are travelling far, of course you'll charge to 100%, and if you are concerned about range, just charge to 90% or even 100% on the fast charger. If you're not, charge to 80% and know you're being as nice as you can to your battery. Going down to 5% is fine, I'm so used to driving E-Golfs and whatever, and their 50% is our 15%. They also have some safety margin, I drove 5km on "0km" with a Tesla :D
Most people drive routes that they know reasonably well, so after driving somewhere once, you know how far it is, when it's nice to stop, etc, and it'll be super easy the next time. It just takes a little bit getting used to.
With the included flexible fast charger what are the single-phase output options? In other words... Can I only choose between 2,3kW, 3,7kW and 7,4kW or can I choose any other kW output in between?
Thanks in advance
Looking at how teslabjorn is doing the 1000km tests. Atleast the ones that i watched, it seems like doing many short stops is the way to go. This makes 100% sense because the car also charges faster at low battery%.
As the charger network gets better in continental europe it will be safer and safer to do this without worrying about if and when you reach a charger at all..
If you wanna do a big 1000km trip in one day you will ofcourse start at 100%, then you will make sure to stop for dinner somewhere your car can be topped to 80-100% meanwhile, and fill in the rest with 3-4 10 to 15min stops.
Scroll down on this article to see a sheet with charged km pr 5 - 10 - 15 - 20 - 25 - full for alot of different cars. Most of it should be readable by non norwegians.
Thanks in advance
i dont know which amperages are included in the default one but usually you can choose many different ones from 2A up to 32A (for single phase) and 16A for 3F by few different settings 2,3,5,8,10,12,16,20,25,32 in some
multiplying it by 230V (or by 690 for 3F) tells you how many Watts you get
Reactions: pafas
Thanks in advance
These numbers are tied to common fuses. In other words, 10, 16 and 32A 1-phase.
32A 230V 3-phase is probably not something that exists in a lot of countries. That would give you 11kW.
32A 400V TN-C gives you 22kW. If you have a modern 3-phase intake meter, you might be able to use this.
If you want to reduce load, I wouldn't be surprised if that could be regulated from the car, don't know if it can be done continuously or by certain steps. If you are concerned about load balance, you should use a dynamic load balancing system that talks with your charger. Easee is a good pick.
Old buildings here (70%) have IT systems here ,neutral is isolated and is not brought forward, 230v between the phases. The rest of Europe afaik use systems where the neutral is connected to ground, so you have 3 phases and neutral, with 400v between the phases. It’s really quite quirky, but has some safety benefits.
afaik only some Tesla can charge 11kW from this type of system, i4 cannot.
I think as EV adoption increases, there will start to be problems with home supply limits being reached. Most people do not have a clue about loading limits on house power circuits. Take my house for example. I have a 100 amp main fuse. If I have the underfloor heating running on it's heating up phase, the cooker going, a kettle on AND I start the car charging, that 100 amp fuse is going to be under serious strain and will probably blow.
That is true but any decent smart EV charger is monitoring the current through the main line coming into your house and will also be aware of the total capacity of the main fuse and will reduce charge rate to stay under the threshold.
How can it do that? If you have an analogue meter you’d need some inductive amp meters installed. Here we have digital meters with a ‘console’ out which you can connect equipment to (HAN port).
Some chargers have load balancing between chargers of the same brand to support several on one circuit, but it can’t know the current passing through other parts of your system.
1 - 20 of 29 Posts
