1 - 13 of 13 Posts
What are people going for?
With the configurator being live now and finally configured what I fancied.
The 19 inch alloys have a range of 316 miles estimate and going to the 20’s drops that to 267 which is a drop of 50 miles range. I like the flared arches with the 20’s and the look with the larger alloys but is it worth that range loss?
It does look cooler but isn’t worth that much loss of range.
I have an additional thought. I'm assuming you are talking about the M50, given your reference to the 20" tires. We already know that the range of the M50 is in the 245 mile EPA range. Is that assuming 20" tires? Or does the loss you have described going from 19" to 20" take you down from that baseline of 245? Put another way, would 19" tires improve on the EPA range estimate?
Discussion Starter · #5 ·
We don’t have the 18” as an option on the M50 in the uk so it’s only 19 or 20’s. the loss is going from 19 to 20’s which is a big jump and too big a jump for me I think.
i4 M50
Hi all,
I ordered an M50 with 20 inch wheels. In my opinion this car needs a large wheel. :cool::p
According to my dealer, it will not affect range that much.
Dropping from 316 miles to 267 miles seems huge. Will it really affect range that much?
Where did you get that info?
Cheers,
Philippe
Hi all,
Cheers,
Philippe
If you go to the online configurator, you can change wheels and see at the bottom of the page how it affects the range. For example:
1050
A US configurator would be welcome. I've played around with the UK configurator, and it has proved instructive. I now understand that things like colors and wheels and interiors are dependent on other choices I make. How much this translates to the US I don't know. Trying to figure out the costs is tricky too because I don't think the prices on the UK site can be directly correlated with US prices. I guess we just wait.
I would recommend 19” for the best look / range / comfort compromise. And go for the red brake calipers if looks are your priority (they look very Porsche S style). The 19” M 861 on the m50 look to me the best.
I have a 640d f13 with 20” M wheels and even with the adaptive drive and adaptive dampers in comfort+ mode the ride is very hard and firm on city driving with holes or roads with bad pavement. I don’t race or push corners at drifting speeds so I don’t take much advantage of the large wheels. They sure look good and give the car a punchier look though, specially for the larger rear tires.
the 20” should also take some range out of the i4 and should be more expensive to replace the tires when the time comes. You can see some range variations depending on wheelsize for Teslas here
I would be specking the m50 in black sapphire with 18” 858 with the blue brake calipers and extended m shadow trim, as I would be looking for the lowest attention option (my personal preference and it would add some points in range and cheaper replacement tires).
regards
regards
J
I will stick with the 19s but damn those 20 inch rims look good
1 - 13 of 13 Posts
