Lighting ▲UP▲
Automatic light control
The lighting switch position where the automatic light control is active. To prevent the low beam to come on when the switch is set to “0”, use the option “Active in position A”.
Values:
+ Active in position A
+ Active in position A and 0
Requirements:
+ “Body Domain Controller” BDC_BODY3 control unit
+ This coding is only possible with one of the OBD adapters listed
here.
Exterior lighting switch-off allowed
Allow the exterior lights to be turned off when the engine is running.
Values:
+ Active
+ Not active
Requirements:
here.
Fog lights off with high beam
Enable/disable the automatic switch-off of the fog lights when the high beam is turned on.
Values:
+ Active
+ Not active
Requirements:
here.
Fog lights with parking lights
Allows the fog lights to be turned on with parking lights.
Values:
+ Active
+ Not active
Requirements:
here.
Hazard warning signal after emergency braking
The hazard warning signal is activated automatically after an emergency braking.
Values:
+ Active
+ Not active
Requirements:
here.
Rain-light-sensor sensitivity
The sensitivity of the rain-light-sensor that affects the automatic wiper and light activation.
Values:
+ Insensitive
+ Normal
+ Sensititve
+ Very sensitive
Requirements:
here.
