BMW i4 eDrive40 Eibach kit
11305 Views 124 Replies 21 Participants Last post by  CEDDY
Hello everyone. Finally Eibach is the first to introduce sping kit for the eDrive40. It is 30mm at the front and 25-30 at the rear.
Part code No is E10-20-053-01-20.
I already emailed Eibach in Germany and they confirmed it with the following restictions.
18Without levelling control.
20Except vehicels with 4WD.
Does any i4 has leveling control?
Soon it will be at their website too.
Reactions: 3
101 - 120 of 125 Posts
@Techwhiz1 certainly has adaptive on his M50.
I have adaptive and Eibach said the kit is for an M50.
I also have the TÜV certification for the spring kit for the car. ACS also has a kit for adaptive suspension and it's just springs and links. They also have the TÜV certification.
It still rides well. Sport is a little stiffer, but that's to be expected. Turn in is better and the car feels really solid.
I exclusively drive in sport mode. Why?
Because I'm coming from a bunch of M cars but my last was a 335i on B8's and M-Sport springs. I like the way it feels in sport mode.
I set the individual options for sport suspension and steering when I picked up the car and never looked back.
2023 M50 - Tanzanite over tartufo full individual leather, 20" wheels, fully loaded.
Reactions: 1
Just curious, what issues would lowering 3/4 to 1 inch thru springs and smaller links cause on the dampening system?
Plus our cars are EDC, so it's electronically controlled.
I wouldn't worry about it, the springs and dampening system aren't even connected, more parallel each other.
What would be considered a successful lowering kit, if that kit still only comes with spring and links?
I don't know, I'm not good with cars. I just see the screenshot from that page I linked and it says not suitable, that's all I'm thinking about :(
@Don Juan successfully installed on his e40 MSport so I just went with it, since it was such a great value @ less than $300 from that site (<$300 vs >$1000 for coilover kit for barely 1 inch drop). Assumed setup should be similar to m50 w/ adaptive. @Techwhiz1 seems to have installed successfully for his m50 w/ adaptive, so I'm pretty sure it will be fine for you as well, if you're still on the fence.
I saw the same thing and still ordered. Earlier post in this thread had some confusion over what it really meant. But people have ordered installed. I’m going to install. I understand the worry. But others have done it
What page are you linking to that says "not suitable"?
This one scroll all the way down to the FAQ:
Eibach Springs E10-20-053-01-20 for BMW i4 (tunershop.com)
Even on your link. it says "All products are tested and fitted with Standard dampers."
So idk if that means not for M suspension or not
Yes, it is unclear. After I found a web browser able to render the Q&A section at the bottom of the page, the answers were not succinct; not confidence-inspiring enough for me to place an order. Also the photos are not representative.
What they need to provide is not a narrative about it, but a concise compatibility chart accompanied by photos of the actual product (that is, the full set of parts you would receive):
model year [202x OR all]
model [i4]
model variant [M50, eDrive40, eDrive35]
M-Sport suspension [yes OR no]
Reactions: 1
M Performance would be considered a standard damper for my car. There is no other damper on an M50.
I have a link for the German site somewhere.
Was your Eibach product number E10-20-053-01-20, for your kit?
I guess what I want to ask is, is dampening the same as suspension.
I have the dynamic handling package, which comes with "M Adaptive Suspension", does this mean I have standard dampening and can use the kit you linked
My understanding is that the M Adaptive Suspension is the electronic dampening system for the BMW, that has been for years. It's what helps dampens and softens your ride in comfort mode. Either you have it or not, just 2 options...
With that said... when installing this kit, I still feel the difference from changing from Sport to Comfort mode. I doubt the kit will cause pre-mature wear and tear on the dampening system...but I'm no expert as well...
Here is a 2020 article regarding the Adaptive M Suspension
States they are Electronically controlled shock absorbers
No my kit is E10-20-053-02-20
Look here: Eibach Springs, Suspension and Stabilizer Bars for BMW - eibach-sportline.com
Reactions: 1
Yep, that's all!
Dropped the car about an inch. Rear links will need to be adjusted accordingly to match front drop. (front wheel will have slight negative camber, but really unnoticeable)
Makes the car look more OEM + (I can barely fit 2 fingers between the gap now, instead of like 4)
And, already scrapped my aftermarket front lip... but the springs were worth it!
BTW can you link your aftermarket front lip lol
It's some cheap AliExpress lip.
Gloss Black option:
https://www.aliexpress.us/item/3256...2wCl3YE&gatewayAdapt=glo2usa&_randl_shipto=US
Vehicle Car Grille Automotive lighting Hood
If you're interested the spoiler was from aliexpress too.
Here's my thread:
See less See more
5
No problem. As long as I’m pointing you in the right direction. Where is your guy located? Did you put up post install photos?
Wheel Tire Car Vehicle Automotive tire
Tire Wheel Car Vehicle Automotive tire
Wheel Tire Vehicle Car Automotive tire
Wheel Tire Hood Automotive tire Automotive lighting
See less See more
Reactions: 2
cant wait to see this look with my rims. Thanks man
Reactions: 1
How is the ride? I'm looking for a verys similar setup. AC Schnitzer lowering and VMR V804 wheels in 19" with 10mm spacers all around.
Do you have problems with speedbumps and steep parking garage entries? IS the ride much stiffer?
I'm on 10mm and 13mm
It's roughly less than an inch drop, the stiffness is there but the difference is not by much. I can feel the roughness on the freeway a bit more than before on Sport mode, but changing back to comfort pretty much dulls that pretty good. Basically, you won't feel a huge change in stiffness, I didn't. (i'm on 19's with 10mm rear and 13mm front).
I try to avoid anything steep for I also have an aftermarket lip installed, and I also take precautions on bumps (slowing down and approaching bumps at an angle)
However, the downside is now all your tires will be at a negative camber. Be prepared to change your tires sooner then expected, re-alignment doesn't help that much.
Reactions: 1
