Picking up i4 M40 this week. I had 240v w 14-50 (at 40 amp) installed. Dealer says I don't need a home charging station because the OEM cable and app will make it redundant. That is contrary to what I read so far. Opinions?
I assume you mean a connected charger, dienst have to be WiFi?The included cable is a combo level 1/2. So you can use it with our outlet and get good L2 charging speeds.
I would recommend checking with your power company for any incentives. Eversource in my area will pay you $200/year to use a wifi connected charger.
Is the car setting at 48 amps? A NEMA 14-50 outlet with an EV car charger should be limited to 40 amps.Agree, the BMW-supplied charger is fine, if you don't mind the extra time to unpack/connect/disconnect/repack the charger/cable (mine is stored in its bag under the cargo floor). The NEMA 14-50 plug connected to a 240V/50A circuit yields 9.9 kw at the 48A setting. That allows 40% to 80% SOC in ~4 hours. Budget more charging time at 32A.
