2022 i4 eDrive40, Skyscraper Gray, DAPP, PAP, Laserlight, Drive Recorder, eSIM Harmon Kardon
Remember that even though the EA chargers says "350kW", the BMW i4 will ONLY except a max of 200-210kW so no need to use up a 350kW station. Let the Kia EV6, Ionic 5 and Porsche Taycan have those stations as the can charger at a much higher rate. This is proper etiquette, don't clog up the faster stations if you can help it.Yep - the 210 kW max charging only occurs at very low SOC (between 0%-20%), then tapers down to 150 kW after 20% and then down to 110-120 kW between 30%-40%.
I look at it this way; whether you start charging at 5% or 25% SOC, it generally takes about 30 minutes to get to 80%, assuming you have a 150 kW+ charging unit. I plan my charging stops for a 30-minute charge; this almost always puts me back at 80% (+/-). As always, be sure to program in the charging station as a destination or waypoint in BMW's nav system so the car can precondition the battery...that will be even more important during colder months.
