How do you charge at home?
1 - 20 of 121 Posts
Premium Member
I'm curious about how different members will charge at home: 110V or 240V FlexCharger or a charging system. If a charger, which one?
Reactions: gsbaker and M3HNGRY
I'm planning on the 240V FlexCharger. This is how I've charged my Tesla for 3 years, no issues. Works fine for my setup. (The only downside is my plug is on the drivers side of the car, where it is on the Tesla, so I'll have to drag the cable around to the other side. This would be an issue with any of the chargers on this list.)
Reactions: gsbaker and ssh
Premium Member
Or back in? ;)
Or back in? ;)
If I back in, then I'm dragging it to the back of the garage (technically further than around the back). Either way it's different. Not a big deal, just different.
Tanzanite M50, red sensatec, carbon fiber trim, red brakes, 859" wheels, DAAP, PAP, premium. lsrlite
I have 2 wallbox brand 45Amp chargers. The one for mine has been sitting and is getting lonely while the one for our X5 gets used every day.
I have a Webasto TurboCord which plugs into a regular 110V outlet, and the car is limited to 12A so I don't trip my breaker. The charger could charge at a higher rate, but I don't have a 240V outlet. The Webasto I believe was rebranded and used for the i3's charger. The BMW Flex charger is too large and unwieldy for me.
The long term plan is to install a hardwired Chargepoint, which is currently sitting in storage because my local utility is dragging its feet on inspection for a main panel upgrade from 100A to 200A. I don't drive very much so this isn't a big inconvenience for me right now.
Premium Member
Discussion Starter · #7 ·
If you don’t mind, it would be great if you’d vote in the poll at the top?
I voted at the top, but wanted to provide some clarity around my decisions. I installed a ChargePoint Home Flex, hardwired. It gives me the capability to charge up to the maximum 48a the vehicle can take which may come in handy in the near future if we get a second EV and want to share. That said, my new employer has free L2 charging so I know where I'll be doing most of my charging now! I didn't want to use the Flexible Fast Charger because I wanted to always keep it in the vehicle in case I ever got stranded somewhere and needed a quick hit of juice. I also want the FFC to stay as clean as possible so it's not dirtying up my trunk. It would invariably get nasty if it was used daily in the garage.
2023 M sport, Black Sapphire Metallic and most of the bells and whitsles.
We are just going to plug into a 240 V using the Nema 14-50 adapter. Our electric company will only give a rebate on Instalation if there is a 40 a and nothing higher. So no need to get a wall unit.
I currently do not have a 240 connection and don't plan on paying a electrician the absurd amount to put one in. I don't drive my car but a few miles a day during week and the 110 will charge 40 miles a night on my car so at end of week im full charge and didn't cost me anything. I don't see spending the money on faster level two plus when you don't need a full over night charge just seems a waste of money in my opinion. plus for some older houses like mine i would have to change the box get some wiring done and..... its expensive to put a 240 in out to the car.
From G30 Individual to i4 M50 Aventurin Red/Mocha
I had a 240v outlet installed ($1200 - yikes) and use the BMW FlexCharger. Works great, once I realized the app defaulted to 6A max. and I was charging at the 120v rate :)
Gas Cable Wood Wire Electrical supply
i4M50
I purchased a Charge point to hardwire but someone else took delivery and I had to request a refund that took two weeks!! I'm so disappointed I've been sitting on my hands trying to decide if I want to buy another at full price or wait to decide later on this year. UGH I'm just so frustrated.
  • Sad
Reactions: gsbaker
Wow, why so high? I spent $1900 for two circuits to hardwire my boxes and those needed to snake through my entire basement's finished ceiling as the garage and panel are on opposite sides of the house. I did spend a bunch of time getting quotes from a bunch of electricians though.
Reactions: gsbaker and rjwc
5.0 V8 Range Rover, Smart Roadster
Myenergi Zappi. I received an email today, asking me to review the Zappi I had installed in February. I still haven’t tried it out!
2022 BMW X5 45e
I was initially going to use the BMW FlexCharger and install a Nema 14-50 in the garage but my electrical panel is on opposite side of the house and quoted $1600.
Currently plan is to charge at work since it's also cheaper per kW.
Voted ssh :) you probably already know my answer hehe
I’ll use the 240 BMW fast charger to start, and then maybe take a look at a wall unit eventually. I need to upgrade my amp from 100 to 200 and get an outlet installed so I would rather not spend more just yet.
E-drive 40 Dravid grey/cognac Msports package with all options.
Plant Audio equipment Gas Cable Wire
Pulsar + wallbox Installed on a 60 amp circuit. Since bmw i4 can take 11kw it would take this 48amp less then 8 hours to charge fully when empty. Unfortunately, in my city, they required a disconnect in sight of the charger since it was a 60-amp circuit.
2022 i4 M50 - Brooklyn Gray - 19" 860M all season - Mocha Vernasca Leather - Carbon Fiber trim
Hardwired Chargepoint.
1 - 20 of 121 Posts
