Leviton n14-50r after 31 months and 95,000km of charging. | BMW i4 Forum
1 reading
270 views 9 replies 5 participants last post by  Hugggy_Bear
I don't often unplug the L2 EVSE I use from the wall, but unplugged it today to use the outlet to power a shopvac as I was cleaning the cars today.
The one hot terminal shows signs of melting..... I'll look at getting a replacement for it.
lasted pretty well for being a $6cdn receptacle.
I would alsp recommend the more expensive "EV Rated" plugs. You can see and feel the build quality on those versus a normal appliance outlet. Mine also started melting and unfortunately damaged the BMW plug a bit, not worth the risk.
I replaced it with a "EV" rated plug. It has more copper in it than the range receptacle I originally used.
Closeup of the damage.
New receptacle:
I used a di-electric cleaner/corrosion inhibitor and a file to get the melted plastic off the plug. Will monitor the temperatures tonight while charging.
Note: currently only charging at 32amp (40 amp breaker); and the L2 EVSE I'm using is only rated to 32amp. The BMW one lives at the lakehouse for the summer.
owns 2023 BMW i4 eDrive40
not sure if the hubbell covers will fit on the leviton receptacles.... if it becomes an issue, i will build a faux box around it and the cover will be flush.
I started to get overheating reports from the Tesla mobile charger
I've always wondered if the BMW Fast flexible portable charger would turn off it the plug got hot. No Wi-Fi so it cannot report it but would it cause a fire?
My Leviton worked fine for a couple of years before it started to give me trouble
Usually it is 3 years. Unclear if this is from cheap plugs like everyone says, or lack of maintenance. On high amp circuits, it usually is recommended every 2 years to re-torque connections. In industrial settings it is standard to check all circuit breakers and plugs every 2 years or more on high amp circuits. Heat cycles can loosen connections. It is best if you can set your charger to a lower setting (32-amps). This prevents the connections from getting hot and eventually loosening over years.
@petee_c What charger are you using? Can you look in the BMW app and see if the charging was interrupted while charging with the bad plug?
The charger at home has been a cheaper cULus rated 32 amp dumb charger from amazon for the past 12 months.
It's cord is 25' long and can reach either bay.
Snugging up the wire connections after 12 months or so is probably a good idea.
My suggestion was not limited to brand. The Hubble was the first one I found. I will be checking all the connections at my earliest convenience! Great suggestion!
