@i4m50Norway If you haven't notified them yet, you can add that there's an error with both Q4 numbers, as they are stating 556 and 557km at 25 min. So for calculating I had to remove both of them from 25 min onwards.
NAF have had a lot of inconsistencies with the id.4/Q4/Skoda. In the Winter test the 2WD Skoda had higher consumption than the 4WD - they even retested with another car, and Skoda also did a new test with the same car. No explanation for this - there is probably more sw bugs to be fixed on that cars.
Hvorfor presterer bakhjulsdrevne Skoda iV80 så elendig i vår rekkeviddetest? Vi tok et nytt eksemplar av samme bil på samme rute. Men svaret var ikke egnet til å berolige noen.
www.motor.no
google translate
The range performance of the Skoda iV80 was so poor that we asked to take a new test with another copy of this model. We have never done this before with any of the almost 120 electric cars we have driven in this test.
For one thing, it went much shorter than promised. The WLTP range with 19-inch wheels and the relevant equipment packages was 509 km. The discrepancy ended at over 30 percent. In fact, this is the only car that has ended up on the wrong side of the 30's.
What was worse was that it went dramatically much shorter than the four-wheel drive version of what is otherwise the same car, the iV80X. Normally, cars with four-wheel drive, and otherwise the same conditions, are between three and six miles shorter than those with two-wheel drive. Now it was the other way around - with deviations from the stated WLTP for the iV80X of a respectable 15.5 percent.
And on top of everything: All the other cars from the Volkswagen Group, which are based on much of the same construction and electronics, also delivered largely good results.
At importer Harald A. Møller, they have scratched their heads over the results and asked to take the same model out for a third test on the same stretch this week.
More about that when those figures are available, but communications director Øyvind Rognlien Skovli says on a general basis:
- These tests are affected by a number of external conditions, and it is immediately difficult to say why this model got a different result in the test than other models built on the same technical platform. The result in the NAF and Motors test does not correspond to our own experiences or other tests carried out in other contexts. We will explore this further, to see what may be the explanation here.
