I fully charged my i4 for the first time and it showed a range of 302 miles which is rather less than the WLTP figure.
I'm new to electric cars and wonder if this is normal
That is most probably because to have used quite a lot of electricity in your previous trips and/or the temperatures is low. On my i3, with WLTP range of 315KM, it reported 305 on Saturday. That was the first time this year with a value above 300, it has mostly been 220 - 250, but saturday was the first day this year with temperature above 10 degrees. And that day I drove my usual 200 km trip, with 100 km available afterwards. Earlier in the Winter it was nearly empty after that 200 km trip. So it estimates pretty good.
here is a link to a test of i4m50 :
Test av rekkevidde på BMW i4 M50. I NAFs rekkeviddetest sammenligner vi modellen på både sommerføre og vinterføre.
nye.naf.no
google translate :
drove 406 kilometers in the range test
The BMW i4 M50 was tested in the winter of 2022. The range test was run under relatively mild winter conditions, with dry roads through large parts of the test. The temperature was between 0 and -10 degrees.
The BMW i4 M50 drove a total of 406 kilometers. It is 91 kilometers shorter than the car's stated WLTP range.
With 10 percent remaining battery capacity, the driver had driven 340 kilometers.
The driver drove 12.4 kilometers after the car reported 0 percent left on the battery.
In total, the average consumption in the test was 19.6 kWt / 100 km
This is how it feels to run out of power
The BMW i4 M50 drove 12.4 kilometers after 0 percent. The driver reported speed limits as the most noticeable effect when the car went into power save mode.
The first warning that the car should be charged appeared at 40 remaining kilometers on the range estimate. The main screen highlighted the range / kilometer with yellow text and a hazard warning. The side screen informed well: The range is very short.
At 0 percent remaining battery capacity, the car was notified of engine power was reduced and encouraged to charge, while the air conditioner stopped working. The driver drove 12 kilometers further before the car lost all traction and stopped.
