@Jack D , I had run flats on my 135i, they have much stiffer sidewalls (to keep the tire rigid enough without air), and as a result, ride a lot stiffer; they also have a higher unsprung weight, further affecting the ride. All of it conspire to increase the rolling friction as well, so I suspect that BMW wanted to keep the range of the M50 to a reasonable value. Mine were also double the cost of non-run-flats for the same brand and size, probably partially due to more expensive build (they need rubber ridges inside to support the rim without air) but probably also due to lower sales volume (popularity of the type and size). Personally, I'm glad to have non-run-flats, though they don't provide a spare either, but then again, tires these days really don't flat very often.
