Mind if I ask which rims you went with? I'll probably be doing the same thing with TireRack. thanks!Went with 18” Michelin x ice on dedicated rims bought from tire rack. Now I just need my car to show up which is currently at port in bremerhaven
I see you have a '23 M50. Did you order the '22 package? It looks like TR does not yet have a package for the '23s. Were you able to get a square set up or did you order a staggered set up?Went with 18” Michelin x ice on dedicated rims bought from tire rack. Now I just need my car to show up which is currently at port in bremerhaven
I don’t think the 17s will actually work on an M50… I think BMW NA has that wrong.The BMWshop has options for 17” winter wheel and tire assembly with Bridgestone Blizzaks or 19” assembly Bridgestone Ultra Grip Performance Winter
I also added those options to the poll
Tire rack does not show 23 i4 M50 as an option, I have just been loo up via 22 i4 M50
tirerack still doesn’t have a winter package for the eDrive40 with MSport brakes.This thread made me realize that I need to get winter tires - I'm not used to doing this coming from SUV world, but with the rear-wheel drive of the eDrive40 it sounds like it would be prudent to get winter tires or it will be hard to risk driving around with a chance of snow or ice!
I'm used to looking at Tire rack - however with the M Sport brake package, it isn't listing any compatible tire packages. There are plenty listed with the standard brakes. I was going to go from the 19" OEM summer tires to 18" winter tires all around.
Any ideas what specs I should look for? From what I've read on other pre-made packages for the i4 - it seems like 225/50 18" should work, but it's not clear to me if these will allow room for the M Sport brakes. The shopbmwusa.com package shows 245/40 19" tires and in the image it shows the M Sport brakes, so I'm wondering if the 19" tires are required for M Sport packages.
I just put in my car being a '22. I fairly confident nothing changed between model years. Let's hope I'm right. I will find out for sure when I get the car as I have a deal worked out with the dealer to do the first switch out. I went with a square setup.I see you have a '23 M50. Did you order the '22 package? It looks like TR does not yet have a package for the '23s. Were you able to get a square set up or did you order a staggered set up?
MSW type 40Mind if I ask which rims you went with? I'll probably be doing the same thing with TireRack. thanks!
