Aftermarket wheels | Page 6 | BMW i4 Forum
101 - 120 of 723 Posts
But in weight you compare 18" to 19" I beleive 19" is allway a bit lighter because of lees rubber?
In my experience bigger rims equals heavier wheels in total, im no expert but that has always been the case for me. I would think the rim weights more than the rubber. (Unless its a forged/carbon rim) :)
Absolutely.
Rear: 18x9 255/45-18 | 24.1KG
Front: 18x8.5 245/45-18 | 23.2KG
HANKOOK VENTUS S1 EVO3 K127
My new setup is
Rear: 19x9.5 255/40-19 | 24.1KG
Front: 19x8.5 245/40-19 | 22.3KG
Kumho Ecsta PS71
Here are some pictures, and i checked with 2 different scales for more accuracy. Note: its KG, not lbs. (Sorry for the quality)
Thank you verry much for this useful info. 👍
The configurator lists Japan Racing SL01 for the i4.
Last time I checked, the load rating is not enough for i4.
Also JR configurator doesn't show any wheels for i4, even if i4 can be selected.
I have contacted JR in Poland and they helped me configure a set of wheels for my i4 m50. 8.5x20" ET30 in front and 10x20" ET40 in the rear. They can handle a lot of weight, Max load is 750 kg, which times four is far more than the total weight of the car. They only weigh 9.9 and 10.5 kg and the 868m 20" OEM wheels weigh 13.65 and 14.33 kg.
Discussion starter · #105 ·
The max load should be more than the rear axle weight divided by two. I4 is not 50/50 distributed, and the rear is heavier.
At least in Finland total weight divided by four is not enough. On the rear, we need 775 kg.
Oh no. Then my Max load is not enough!!! I really hope those extra 25kg is no problem. How Do you calculate the axle rating? I cannot find any numbers for it.
Discussion starter · #107 ·
The max allowed weight on rear 1550 kg.
The car itself does not weight that much. This is the weigh with the car loaded with as much people and luggage as allowed.
I don't know if that 25 kg difference really matters anywhere besides the yearly inspection.
I also think the numbers are precautions and safety by far. The actual breaking point is probably a bit over 800kg. I guess i wont floor it while heavily loaded.
I'm looking for wheels for winter with the 18" square setup (245/45). Since these are winter, I'm thinking I want some which look nice, but can take the beating of sand on our roads, mag chloride, and wet while having a lower weight but obviously be able to handle the i4 M50 load. Thoughts?
