Let's talk about how BimmerUtility is working on the i4. I plan to pick it up soon, but know others have or will shortly use it, like @Techwhiz1 and @larbel.
I think I saw this in BU in the regular section, but I'm afraid I don't remember where. I can likely check over the weekend as long as I find time to get to it!Has anyone used either BC or BU to remove the speed limiter function to enable text entry while in motion? I would think that this option would be located under the expert section. Where would you find this option?
In BimmerCode it is in the expert menu options.Has anyone used either BC or BU to remove the speed limiter function to enable text entry while in motion? I would think that this option would be located under the expert section. Where would you find this option?
By which you mean the lights which light up the ground outside the vehicle when we approach it?Does anyone know if there’s a way to keep the carpet lights on while driving?
This happened to me after an update a few updates ago.I noticed yesterday that my ambient lighting has switched back to citrine and no longer uses the custom color I had created. Anyone else see that? I suppose it could’ve happened after the upgrade, but I thought I had coded it after the update.
Could also be because I'm using both Bimmercode and BimmerUtility. Finding the lighting in BU was a challenge today (never did find it).I noticed yesterday that my ambient lighting has switched back to citrine and no longer uses the custom color I had created. Anyone else see that? I suppose it could’ve happened after the upgrade, but I thought I had coded it after the update.
That one is BLE so it wont work. BU only supports ENET or ENET wi-fi adapters![]()
OBDLink CX
When looking for a top-of-the-line OBD II adapter that works with BimmerCode, look no further. At OBDLink® we have the right scan tools. Purchase here!www.obdlink.com
Does this work with Bimmer Utility? and it Bimmer Utility a little more user friendly than Bimmer Code or are they just pretty much the same animal.
I'd say it's easier to just buy the one they sell on their website.you will need to use one of the OBD adapters that we support. Please note that we only offer assistance for ENET cables or ENET Wi-Fi adapters
Apparently, it also seems brand dependant. Had the option on my Mercedes as well and that worked, but not enabled on the i4?I don’t believe so, unless there’s a way to change the geo-blocked features. I recall other members saying that certain features enable/disable when they cross the border, like the ones you mentioned, as well as traffic light/sign recognition, etc. I’d love to get traffic sign/light recognition to work. I saw some videos in Europe where they get yield/stop signs in their HUD. We don’t get that in North America![]()
You do not need a PC and the license is for all platforms .Hi all,
I would like to give BU a shot and have two questions to start.
It says it runs on PC and mobile. Is a PC needed for initial setup, or can the whole thing be done on an iphone?
The license fee is about $100. Is this per year, or is it a permanent license?
Thanks
George
Do you happen to know the original source?There're a lot of things can be done, like coding your dash display as M3 dash display, but it would also break something along the way since it wasn't designed to display it on the i4. Here's someone coded his i3 (China full electric G20 3 series) to M3 display...
Than kyew!You do not need a PC and the license is for all platforms .
It's a permanent/perpetual license.
2023 M50 - Tanzanite over tartufo full individual leather, 20" wheels, fully loaded.
Likely for reliability. ENET (wired) is much more reliable. I've had my Bluetooth OBD2 VLink disconnect at times and I was just using it for ABRP live data. Just get the ENET wired adapter.That one is BLE so it wont work. BU only supports ENET or ENET wi-fi adapters
Adapter | Bimmer Utility
www.bimmerutility.com
