BimmerUtility on i4 | Page 5 | BMW i4 Forum
81 - 100 of 264 Posts
I got Bimmerutility and managed to open the FA list and delete 5AP, by clicking the box with a check mark. To my surprize the box did not remain empty, but the whole 5AP item disappeared. I had expected that I would have been able to undo the action.
Then belatedly I found a way to save the configuration.
I exited the program then reentered to see whether the change remained and it did.
Last night I went out to test it on a dark road. The auto high beams worked as before. I still get the nice low beam adjustment to just below the hood line, but now beam splitting.
Interesting, the car picked up lights on the roof on a store up ahead and adjusted the lowbeams to the roofline of the store.
I am a bit out of my depth for future tinkering. Can anyone explain what option I need to add now to get the beam splitting and how to add it in BU?
Also exactly how to save and restore my current configuration?
Much thanks, vielen Dank, merci beaucoup, etc.
PS
I did not reboot the car, just normal shutdown
Discussion starter · #83 ·
I'm not following what you're trying to accomplish... it seems like you've gotten it working?
I would like to enable the laser antidazzle function.
The disable code on the production sheet is 5AP, decoding for no-dazzle high-beam assistance.
FA is the German name for the VO list, as it shows up in BU. I deleted 5AP from the list but saw no way to reverse that, and was worried. So I stopped there.
A few days later I took the time to drive out to a very dark road to test. The function was unchanged from my original settings: low beams adjust their height as high as possible up to the level of the other vehicles' lights; absent lights the high beams shine higher and much brighter; both headlights move together up and down.
I was happy that I had not ruined it, but was hoping for a split between the left and right headlights, as in the bmw video.
So I wonder whether there is now something to add in the coding. Or is there some type of reboot I need to do?
If someone has gotten the full antidazzle function using BC or BU, can they guide me?
also guidance on backing up my configuration so I can restore thing.
thanks
Is BimmerUtility able to access the headunit on iDrive 8.5? BimmerCode falls short unfortunately.
Any way I can test this out using my OBDLink CX?
The bimmerutility.com web page lets you ask for texh support. I saw somewhere a long list of compatible OBD adapters that are supported.
you may ask them about yours before you buy the program.
Discussion starter · #87 ·
My current understanding is that coding will only be possible when connected to the BMW cloud services.
For those of you who have used both BimmerCode and BimmerUtility, is there a preference one way or the other? Are you also employing Esys and PSdZData?
BimmerCode does not have the full PSdZData. BimmerUtility does… mostly. So BimmerCode will not allow you to access several of the ECU’s. BimmerUtility is a more complete product.
Discussion starter · #96 ·
Does this tool allow the colours to be changed on the Speed/Power screen, I hate the wishy washy colours that come as default. I used Bimmercode to change my X3 colours to Alpina which were a lot better, not seen any option in Bimmercode to do this.
when you say “speed/power screen” are you talking about the left side of the display, behind the steering wheel, where the drivers display is located?
if so, there may be some options in the HU_MGU ecu that could possibly change that scheme, as I believe the HU in idrive 8 / 8.5 control that screen as well. If you have Bimmercode, you’ll need to try expert mode to find them though. I did see one or two in bimmerutility relating to different schemes… but I haven’t tried setting them.
