EuroPartsOnline is proud to announce our all-new Hub-Centric Wheel Spacers Kit lineup for all The New BMW models with the 5×112 Bolt Pattern and 66.5mm Center Bore.
Our wheel spacers are an excellent, cost-effective way to enhance the look of your BMW vehicle and improve handling. Our wheel spacers push your rims and tires outward to give your vehicle that aggressive look it was missing from day one. You can expect better handling & stability. Spacers will also allow you to run larger brakes and upgraded suspension. If you are looking for that tucked, poked or flush look, our wheel spacers can assist you in that desire. Each kit includes 2 Hub-Centric Wheel Spacers and the required extended lug bolts to easily mount them to your vehicle.
WHY CHOOSE EuroPartsOnline? We have the best wheel spacers on the market at the best price period! They are Precisely machined and specifically designed according to the manufacturer’s specs, these spacers are forged out of the highest grade T6 7075 air-craft grade forged aluminum alloy and black anodized to ensure durability and reliability under the toughest of conditions. Our Included Extended Lug Bolts are actually manufactured to exceed OEM specifications and ratings.
PERFECT FIT: 100% Hub-centric and specifically designed to fit your BMW.
HUB-CENTRIC: Means that the spacers center bore matches your factory hub and the factory-like hub on our spacers matches the center bore in your wheel for a vibration free fit.
EASY BOLT-ON INSTALLATION: Our Wheel Spacers are engineered as a direct-fit upgrade and require no modifications for installation. We recommend the use of a Torque Wrench to ensure proper tightening of the hardware.
Our Wheel Spacers are sold in pairs (2pcs) with (10) extended lug bolts. To do the whole car you will need 2 spacer kits.
BMW i4 Size Suggestions*:
V/R
Anthony@EuroPartsOnline
*Note: These are just my suggestions, but you can run more or less depending on your style/taste of the wheel fitment.
with no Fender Flares
Rims: 18x8.5 ET36 and 18x9 ET42
Front: 10mm or 12mm for really flush
Rear: 12mm or 15mm for really flush
Rims: 19x8.5 ET35 and 19x9 ET42
Rims: 20x8.5 ET35 and 20x9 ET42
With Fender Flares
Rear: 25mm or 28mm for really flush
Rims: 20x8.5 ET35 and 20x10 ET39
V/R
