I'm shortly moving to an M50 from my Polestar 2 and have a question about how braking works on the i4.
The Polestar 2 uses what Polestar refer to as 'soft braking', where regardless of the regen setting (even if it's turned off), when you apply the brake pedal it will initially use regen to slow the car, only physically applying the brakes if additional braking force is required. Driving the car, you don't notice this, you just get the traditional "press the brake pedal and the car slows down or stops" experience. In fact it probably took over a year of owners arguing on social media and Polestar finally confirming it before people even realised that this was how it worked.
In theory this is all well and good, as there's no loss in braking efficiency or predictability and there's less wear on the brake pads and discs. However, lots of owners like me are now finding out that after a few years of ownership, our brake discs are getting badly pitted due to lack of use. Basically, even if you have one pedal driving/regen braking turned off completely, if you're a smooth driver it's likely that your physical brakes will hardly ever be used unless you deliberately brake aggressively every now and then.
So my question is, does anyone know for certain whether braking on the i4 is also a hidden combination of regen and physical braking? I'm thinking that if BMW use permanent magnet motors in the i4, then actually it would have to be, due to the basic physics of electromagnetism.
