CarPlay GPS Inaccurate | Page 17 | BMW i4 Forum
Tags
carplay
2 reading
139K views 973 replies 124 participants last post by  ssh
#1 · (Edited)
Mod note: BMW have acknowledged this as as issue and a fix is due May/June 2023.
I've been having an issue with the CarPlay Maps issue since I've had my i4. When using Google Maps/Apple Maps through CarPlay, after some amount of time the GPS location becomes inaccurate, showing my location around 100 feet from where I actually am. The longer I am using the navigation the further off the GPS location is. It appears to lose location when I drive under overpasses or near obstacles that may cause the car to temporarily lose GPS signal.
The problem persists even after restarting the car. It is only fixed once I reboot my phone and/or reset iDrive by holding the power button for 70 seconds. I don't think its an issue with my iPhone because I have tried multiple phones and all of them have the same issue.
I looked up the problem and other people have the same issue with different cars. Apparently, the iPhone uses the car's GPS when connected to CarPlay. The car is sending bad location info. People were only able to get it fixed after getting a new headunit in their car or updating their firmware.
Here is an Apple forums post describing the issue: Everything works in Apple CarPlay except … - Apple Community
Does anyone else have this issue with their i4?
*I have the latest update - 03/2023.53 and have not had the bug since. Been running it for a couple weeks.
<-- Holding back a snarky comment.
You're welcome.
Reactions: asunners and ssh
GPS is, of course, originally a US military system. The guidance for using GPS units in military manuals states that the GPS signal can be blocked by dense foliage.
I'm pretty sure that a car's roof and chassis is better a blocking RF signals than some leaves. This is why car GPS units have always either had an antenna outside the car or was mounted to a window.
In order to get an accurate position, at least 3 satellites must be in line of sight of the receiver. That's certainly easy enough when you're not inside a Faraday cage.
Just sayin'.
Reactions: gsbaker and ssh
#11 ·
No modern systems are completely reliant on GPS alone, they also use cell tower triangulation and wifi to assist with geolocation which have no problem with going through a window.
There's something wrong with the software. I have had the exact same problem and I had it 2 days ago. I was driving with a friend and both Apple and Google Maps had me 100-200 meters off the road so it looked like I was going through the yards. I joked to my friend that Google is gonna start serving me ads for ATVs.
When my friend opened Google Maps on his phone while in my car, it was spot on, no issues with the signal.
I experienced this issue recently in my dealers demo i4…. I haven’t noticed it in my M50, yet…. But I’ve only driven it about 10 miles, from the PC to the detailer. Will see how it goes on the 500 mile trip home on Saturday.
Location of the phone itself can impact this. In the charger bay, there's a booster for GPS reception, but in other parts of the car, the GPS reception can be impacted and so it can go wonky. Same is true in my 330.
This is happening to me with CarPlay on the i4 as well. Haven’t found a way to fix it yet…
My gps location always shows me about 3 blocks away from my actual location. Kind of funny to see it show that I’m driving over buildings :ROFLMAO:
As mentioned earlier in the thread, the idrive gps location works fine, but the incorrect location only appears in CarPlay.
I’ve tried rebooting the phone, rebooting the car’s infotainment, with no success.
Sometimes it decides to work just fine, though…
This never happened in my 330i which also had wireless CarPlay. Hopefully this gets fixed with a software update
Thanks for the replies. CarPlay actually uses the car's GPS, not the phone's, when connected wirelessly. It's in the specs for CarPlay. They did this because the car's antenna should work better than the phone's as its exposed on top of the car.
The strange thing is that the car's navigation works properly.
Being 100 feet off is still within the GPS specifications for the C/A code for civil signals vs military. The cell phones use assisted GPS, they rely on wifi cellphone signal gps time for initial position acquisition.
Is/was the phone in the charger in the console, or in your pocket? I had some screwy GPS things happen with Apple maps until I took the phone out of my pocket and put it in the charger. Remember when using Carplay it's the GPS in the PHONE that has to get the satellite signals. With the HUD I will typically use the built in nav as it shows the graphical road map during turns. With Carplay you only get arrows and text.
CarPlay doesn’t use the car’s GPS. It wouldn’t work with cars without navigation. If you have the phone in the charging tray the accuracy will probably drop, especially if you are driving in areas with high rises that might block the phone’s GPS antenna signal.
#125 ·
As far as I understand, this is not correct, it is an Apple requirement for Developers that wireless CarPlay must use the Car provided GPS. You can see the WDC documentation from Apple that states this here and the reasons why (primarily assumption that wireless CarPlay may mean the phone is in a bag or a pocket and suffer poor GPS reception):
