Anyone has a reliable source that provides ground clearance for i440? As even at my dealership they do not have that figure - I have found just one website that says 12cm (and wanted to confirm on that)
You are right about not lowering/rise manually. But they included air suspension in the rear, see here on the 6th bullet “Lift-related dampers and rear-axle air suspension come as standard.”i dont believe they do - asked my dealler and it is only a stiffness option not the lower/rise one
Interesting...do you know what "transport mode" is? Does this mean for when it is being transported on a truck or train so it is raised a bit incase a big bump is hit or is this something that can be turned on and off and then driven...basically lifting the car when needed? That would be fantastic but I think unlikely.I just hope these impressions from the configurator are realistic.
In many photos that BMW used, mostly during the first formal presentation, the car seems to be a bit too high, especially at the rear...
The i4 M50 that I saw for real during a preview was even higher than the car in the picture below. The BMW genius explained that the car was still in transport mode. Hmmm, let's wait and see
125mm=12.5'mAnyone has a reliable source that provides ground clearance for i440? As even at my dealership they do not have that figure - I have found just one website that says 12cm (and wanted to confirm on that)
Um. I think either your your math or your units may be off.125mm=12.5'm
**itUm. I think either your your math or your units may be off.
125mm = 12.5cm = 0.125m = 4.92 inches = 0.410 feet = 0.136 yards
I don't believe this is correct. There are two options with Adaptive suspension, Comfort or Sport. The suspension continuously adapts in both settings depending on the road conditions and your driving style. You can't switch this off. If you select Comfort, the algorithm continuously adjusts between, say, Soft and Medium and if you select sport, it will adjust between Medium and Firm. I don't actually no how much overlap there is between the Mediums but you get the idea.Indeed the adaptive suspension is controlled by the ride modes. So there are 3 settings:
And if you will there is a fourth setting which is the manual override than can be set in eco pro individual or sport individual. Here you can manually choose between either sporty or comfy suspension.
- Firm suspension which will be activated by sport or sport plus mode. Sport plus is called sport boost in the i4.
- More comfortable suspension which will be activated by eco pro or comfort mode.
- An adaptive damper setting where the car will continuously choose between firm or more comfortable suspension depending on the circumstances of your ride, activated by the adaptive mode.
The comfy setting can be compared to the setup of i4's with the standard suspension.
None of these settings have anything to do with ride height. That is preset in your configuration, once your order is taken into production it can not be changed.
